vcDetachProductStatement
Detach statement detaches the component(s) of one or more products from the component of a common parent product. The products to detach can be filtered by type.
DetachManyBooleanRWGets or sets the detach many value. When True, detaches all products that match the filter, otherwise only the first one.
DetachedProductVariableNameStringRWGets or sets the name of output variable where to store references to the detached products.
FiltervcProductFilterRGets the filter.
ParentProductVariableNameStringRWGets or sets the name of input variable from which to get the parent product instance.
demoteFromCombinationFiltervcProductFilterNoneDowngrades back to filter, filter count must have 1 or 0 filters.
vcProductFilter: The modified filter.
TypeError: When the filter is not a CombinationFilter.
TypeError: When CombinationFilter has more than 1 sub-filters.
promoteToCombinationFiltervcProductFilterNoneUpgrades current filter to combination filter.
TypeError: When the filter is already a CombinationFilter.
replaceFromvcProductFiltervcStatement statementSets filter from other container.
statement (vcStatement): The statement to replace the filter from. Has to be a statement with a filter container.
AttributeError: When argument is a statement without a filter container.
setFiltervcProductFiltervcProductFilterType filterTypeSets to specific filter.
filterType (vcProductFilterType): The type of filter to set to.
vcProductFilter: The new filter.
AttributeError: When the argument filterType is ProductType.
NameParametersDescription
OnFilterChangedNoneTriggered when filter is changed.
